Tractor Talk Discussion Forum
1994 Dodge 2500 diesel
Rich Iowa
09-04-2006 18:37:57
I found a 1994 Dodge 2500 with the 5.9L Cummins, reg. cab, long box, 4x4, auto at the local dealership tonite while i was glancing around in search of something to replace my Dodge Dakota. The odometer shows 155,948mi, one owner, the interior and exterior are in very good shape, new tires up front and 50-60% tread on the back. I currently have a 1996 Ford F250 with the 7.3L Powerstroke which I plan on keeping. I"ve been around the Cummins before, but I"m not real familiar with them. What kind of milage Could I expect out of a truck spec"d like this one? my "96 Powerstroke gets averages 18mpg during the summer.
Does anyone have a Dodge of this year or close to this year that can give me some opinions and ideas on what to check for on this truck. I"ve heard some bad things about these Dodge auto trannys, anything i can look for besides looking at the tranny fluid? This truck appears stock, but there is a gooseneck hitch in the bed which has me wondering about the tranny. How about the brakes on these trucks, any good? Thanks for any and all help you guys/ gals can provide.
Fluggie in IA
09-05-2006 06:55:19
 Re: 1994 Dodge 2500 diesel in reply to Rich Iowa, 09-04-2006 18:37:57
I agree with Cliff. Keep the tranny temp below 200 and it'll last a long long time. My father-in-law's 94 just like this one has almost 200,000+ on it and never has been repaired and he hauled lots of 400 bu loads of corn out of the fields with it. The weakest item on any of these full sized Dodges is the front end, especially on Diesels since the Cummins weighs so much more than the gas. All else is well designed and built heavy including the brakes. I worked for a construction company that had all Dodges (diesel and gas) and frontends and trannys were 99% of the repairs but mainly due to abuse, not poor design. By the way, the Cummins engine is designed to go 250,000 mi before minor overhaul and 500,000 before major in normal usage. That info is from a Cummins engineer I knew.
Maple Springs
09-05-2006 06:25:16
I have a '94 Dodge 2500 with the Cummins and the automatic transmission ,with now 170,00. The engine has been flawless.
The transmission, however, is another matter. I bought it from a friend, who used it to pull round bales from the field to the barn. The truck had 75,000 when I bought it from him, and the transmission crapped out at 95,000. When the dealer rebuilt it [for over $2000], he said that '94 was the first year for that transmission and it didn't have the guts to withstand the diesel's torque; the standard transmission, he said, would be fine. A couple of years later they redesigned the automatic and have apparently been OK for hauling.
I've been leary about the whole thing, though, and never pull anything very heavy. If I do decide to pull a trailer of some size fairly regularly, I think I'll trade trucks, perhaps keeping with the Cummins but going for another transmission.
Oh, with my truck -- the auto has O/D -- I get right at 20 mpg on the road.
Mark
John S-B
09-05-2006 06:19:43
I have a '95 and the only problem I have with the tranny is that when it is cold it takes a couple of minutes at highway speed for the OD to kick in. It has always done this. I don't haul all the time but I always leave it in OD unless I go thru some good size hills or mountains. In Oh. it's pretty flat so I can go 65 with a load. Around 18-20 mpg should be normal with this truck.
bm3501466
09-04-2006 19:07:16
Normally these transmission will hold up just as long as you don"t lug them. When towing just take it out of OD.
Cliff Neubauer
09-04-2006 18:49:40
I have a "99 2500 diesel with the automatic. Those auto"s aren"t the best ever built but with an aftermarket torque converter, valve body and shift kit they can be built extremely strong without spending alot of money on them. If you get it I would change the transmission filter/fluid and install a transmission temp guage, if you keep the transmission under about 200� it will last along time but much hotter than that will start to break down the fluid which will lead to problems.
