Tractor Talk Discussion Forum
PT-10?
Jeff From WI.
09-03-2006 15:54:56
Hey guys, I have 2 Hesston PT-10 Haybines. The One That's in Great Shape The Gear Box that Drives everything Just went out. On my other one the gear box is fine. Does anyone know how to change these out? It Has the bolts on top Which Looks like the easiest thing to do. And then It Looks Like??? Is there a Simple way to do this? Or do I Just go under it with a Cutting Torch and let it go??? And then buy new joints? Thanks For all your Help. Jeff From WI.
Harold Hubbard
09-04-2006 05:19:03
 Re: PT-10? in reply to Jeff From WI., 09-03-2006 15:54:56
It's been awhile since I did that, but if I remember correctly, the worst part is getting the pully and the idler pully arm off the output shaft. I seem to remember a lot of heating and beating, and I may have torched out some bearings to get it all free. The input shaft should just slide out of the coupler, but you may have to remove the tongue and slide the shaft forward to get enough clearance to drop the box.
