Tractor Talk Discussion Forum
PHOTO - the ultimate classic tractor
David in Wales
08-31-2006 11:25:43
third party image
Bore da;
This is the Doe Triple D - the most sought after tractor in England right now.
Triple D = Doe's Dual Drive.
Designed by Mr Pryor in Essex (SE ENGLAND) who wanted a 4wd hi HP tractor for his heavy clay land. The ultimate design & manufacture was done by Ernest Doe from Essex a large Fordson dealer. Built from approx 1957 onwards on Fordson Majors then on Ford 5000's until the mid-1970's.
The Majors turned out some 100HP and the last 5000's some 130HP in total. The driver controlled the front tractor from his seat on the rear tractor with electrically switched motors & hydraulic valves. The front unit will turn 90 degrees (right angle) giving a very tight turning circle. Doe also built specially heavy duty ploughs & cultivators to match these tractors.
They also built a few Doe 5100 tractors using a Ford 6 cyl industrial engine fitted into 2wd Ford 5000's.
Approx 500 were constructed over the years, many were converted back into normal tractors or broken for spares. Hence the value to-day could be well over $100,000 in auction !!!
Incidentally Ernest Doe are now the largest New Holland dealers in England.
Ive seen photos of 2 Volvos in Sweden and 2 JD 820's in USA of a similar construction & design.
Hope you enjoy seeing something a little different.
Cheers David
MJ in the UK
09-01-2006 03:45:22
 Re: PHOTO - the ultimate classic tractor in reply to David in Wales, 08-31-2006 11:25:43
Here in the east of the UK we have a large intrest in the DOE tractor and can get up to 15 at a time at shows and working days. A friend of mine has built a similer tractor using two MM UTS tractors with Perkins diesel engines. Also we have a dual DAVID BROWN 995 and several dual FERGUSON TE 20s. The most expensive do i have known was �66000=00 MJ
Earl-IL
08-31-2006 20:08:40
Great pictures. When I lived on the farm in central Illinois I had a neighbor put the 330 6 cyl engines in 2 of his 4 cyl Majors. If I recall he got them from a Ford Trucks that hauled RC Cola. I think they were Dagenham Thames engines?? Earl
morningwood
08-31-2006 19:05:15
David,
Do you have anymore pics of the Doe ??? Posted your link over at fordson.freeweb.nl and we were just wondering if it is a power major or super. Plus us fordson guys lover our Does.
Thanks,
Scott
P.S Keep the pics coming, they are great.
Nebraska Cowman
08-31-2006 17:36:40
I am aware of at least one Ford 5000 version here in the States. Thanks for the pics, I had never seen one based on the Major. It was popular here in the west for a while to build tandems. I see quite a few, Massey 55, John Deere 820, LA Case, 99 Oliver, International W9, etc.
JOHN HARMON
08-31-2006 17:04:28
Interesting: would be amazing except in the 1960's and 1970's here in the "Colonies" many apparitions such as this were put together and performed mostly with out fault. Two Farmall M's-Two John Deere A's or two Deere G's or two MM U's and I saw Two D17's AC once .All teamed together to pull 5-6 bottom Plows.Then the 4010 JD and the 560 Farmall showed up one day and all these Mechanical Marvels were rendered obsolete.The larger 5020 and 660 Farmall and all the other large Tractors were capable of pulling up to the 6 Bottom plow size and then the Articulated Giants showed up to pull plows no one dreamed possible. 8--10 bottom plows if used now are common.I am not slighting your double up just trying to communicate that this mechanical marvel is and has been around a spell. Enjoy your input to the YT forums. John
NoahW
08-31-2006 14:47:27
From Essex? He didn't have anything to do with the ETD did he?
