Tractor Talk Discussion Forum
Satoh 370D Clutch help?
brian175
08-30-2006 16:32:56
I have a Satoh Beaver and let it sit for six months , now the clutch will not dissengage, worked fine before.Any ideas before I pull the engine?
Mike M
08-31-2006 04:33:19
 Re: Satoh 370D Clutch help? in reply to brian175, 08-30-2006 16:32:56
Get a clear open path get it going and try to get it going in a higher gear then just stab one brake pedal it may take more than once. I have had very good luck with this method.
JJ
08-31-2006 03:49:34
I have a 373D that has had the same problems. In the past I have been able to rock it back and forth and it has broken free.
billy in new york
08-30-2006 18:55:54
another trick that isnt real safe is to depress the clutch pedal.start the tractor in low gear and while moving spike the brakes (with the clutch still depressed )alot of times this is enough to break the clutch disk free from the flywheel.just make sure the path in front of the tractor is clear. i would be careful with any kind of oil around the clutch disk as this can cause slippage. bill
brian175
08-31-2006 11:20:46
 Re: Satoh 370D Clutch help? in reply to billy in new york, 08-30-2006 18:55:54
Well I used the driving and spiking the brakes technique: It worked, However, I lost 1st gear and reverse (I was in 1st gear at the time)When in 1st the tractor moves slightly with a little gear noise, reverse no movement lots of gear noise. 2nd and 3rd work fine, no other damage. How much fun am I in for fixing the gears? any idea what I broke? I have a repair manual.
Mike M
08-31-2006 11:50:24
 Re: Satoh 370D Clutch help? in reply to brian175, 08-31-2006 11:20:46
That might be why I was told to use high gear ? Less engine power and more shocking effect with a brake stab. I'd check for a broken/bent shift fork.
Mike in Ind.
08-30-2006 16:57:39
There isn't any sort of inspection hole or plate you can take off to get to it is there? if so a good rap with a small mallet or hammer usually does the trick. Some WD40 or such helps too. Mike.
brian175
08-30-2006 17:04:18
 Re: Satoh 370D Clutch help? in reply to Mike in Ind., 08-30-2006 16:57:39
I thought about hitting it, (but didn"t) I will look for inspection plate. thanks.
