Tractor Talk Discussion Forum
pump
chad d drane
08-29-2006 19:33:31
does a 70 john deere have a fuel pump that runs off oil
onefarmer
08-29-2006 19:42:56
 Re: pump in reply to chad d drane, 08-29-2006 19:33:31
It is not a pump but a pressure actuated fuel shut off. Open when running and engine builds oil pressure, closed when engine off and no pressure. There is a knob on top, to manually open to fill the carb when needed
chad d drane
08-29-2006 19:49:54
 Re: pump in reply to onefarmer, 08-29-2006 19:42:56
can i put a regular valve on it this one is leaking
onefarmer
08-29-2006 19:56:50
 Re: pump in reply to chad d drane, 08-29-2006 19:49:54
Take it out put in a regular one and plug the oil line. Dad did that to now mine 620. Wish I could find the old shut off though
buickanddeere
08-29-2006 19:37:48
Lawn and garden model 70? Field tractor model 70 in propane, gasoline, all-fuel or diesel? We can't read minds. Fuel is controled by oil on some of the later 70 field tractors.
chad d drane
08-29-2006 19:39:47
 Re: pump in reply to buickanddeere, 08-29-2006 19:37:48
gas farm tractor 70 pump in sediment bowl
buickanddeere
08-30-2006 15:31:04
 Re: pump, fix it right or wish you did in reply to chad d drane, 08-29-2006 19:39:47
Rather than doing a farmer fix and disabling two safety systems. Just purchase a couple of cheap diaphrams and a valve/seat from Mother Deere. Low oil pressure shuts the engine down to save it should the operator run her low. The low oil pressure shut off just about eliminates finding the gas tank empty and the crankcase full of gasoline. Should the carb needle/seat seap a little of get some dirt stuck in it.
