Tractor Talk Discussion Forum
Hole in battery revisited
Cosmo
08-28-2006 16:48:11
Thanks to all who offered advice yesterday. So here's what I did. The hole was only pin sized so I hand reamed it with a 1/8 bit and inserted a slightly larger well siliconed nylon screw and then covered the head with it. I added enough water to cover the hole and it is holding so far. Thanks again men. Regards, Cosmo
souNdguy
08-29-2006 08:22:07
 Re: Hole in battery revisited in reply to Cosmo, 08-28-2006 16:48:11
Hit walmart, napa, TSC, etc.. and get an epoxy stick. The sell one SPECIFICALLY for battery repairs.. and it is acid resistant. they also sell ones for gas tank repairs that will stick and bond to metal that is gas-wet.
Tilt the battery so there is no fluid leaking.. remove your patch and ALL rtv.. may have to scuff with some 1000 paper. then follow the directions on the stick.. mix and patch.. usually cures within a few minutes..
Soundguy
RAB
08-29-2006 01:09:05
 Re: Soapbox again in reply to Cosmo, 08-28-2006 16:48:11
Cosmo,
You wrote previously:"a good bit of acid ran out"
If it was a "good bit", and particularly if the battery was fully charged, you should have topped up with diluted sulphuric acid of the correct speciic gravity, not water, to do it right.
Regards, RAB
jones in texas
08-28-2006 18:22:48
That is correct .sulfuric acid will desolve nylon.
Bluedice
08-28-2006 16:58:11
What happens to nylon in hydrochloric acid?
I think battery acid is H2SO4 -sulfuric. Not that there would be much difference in pH.
ErnieDD
08-29-2006 15:58:23
 Re: Hole in battery revisited in reply to Bluedice, 08-28-2006 16:58:11
We had some 1/2" nylon tubing connectors in HCl service, they last for a while and then crumble.
ErnieDD
08-28-2006 16:52:42
I know for a fact nylon is incompatible with hydrochloric acid, I would keep an eye on the patch.
Cosmo
08-28-2006 18:40:34
 Re: Hole in battery revisited in reply to ErnieDD, 08-28-2006 16:52:42
Whoa, back to the drawing board. I'll keep a close eye on it. Thanks for the heads up. Cosmo
