Tractor Talk Discussion Forum
1948 ih f-cub
bob col
08-26-2006 13:04:55
just installed a new coil
engine starts right up, but lopes.the govener keeps trying to compensate,which makes the problem worse.
help me
bob c
Don L C
08-26-2006 21:47:00
 Re: 1948 ih f-cub in reply to bob col, 08-26-2006 13:04:55
Try backing out the high speed screw on the carb.
Count the turns out, 1/2 turn at a time, so you can put it back if it dont help.....
Might be a good time to take the carb apart ....soak a day or two in lacker thinner ,blow out all passages and check needle and seat.....
old
08-26-2006 13:32:09
Friend has a cub that does the same thing when first started then it evens out. The problem on his is in the carb but since it even out we don't worry about it. On yours its probably some junk in the carb causeing the problem. Try chokeing it and if that helps then you know for sure its the carb and it may need to be rebuilt.
