Tractor Talk Discussion Forum
DIESEL LEEK
pete hodge
08-26-2006 04:48:58
I HAVE A JD 2650 AND WHILST PULLING SILAGE TRAILERS LAST NIGHT I NOTICED I WAS LOOSING DIESEL ON THE ROAD,I NOW DISCOVER THE BACK AXLE IS FUUL OF DIESEL AND POURING OUT OF THE DIP STICK IF ANYONE HAS ANY IDEA WHY AND HOW I WOULD LOVE TO KNOW MANY THANKS PETE
HTR
08-26-2006 15:32:10
 Re: DIESEL LEEK in reply to pete hodge, 08-26-2006 04:48:58
Has anybody done any work in the front of the tractor, for fuel leak or hydraulic leak, or any other reason? The only thing I can think of is, somebody crossed the fuel return line, from the injectors and injection pump, with a bleed line from the hydraulic cooler, hydraulic pump, or the air line on top of the oil reservoir.
MSM
08-26-2006 05:38:44
Either the diaphram in the transfer pump has a hole in it or the seal on the injector pump drive shaft is bad, either one will put fuel in the crankcase.
PETE HODGE
08-26-2006 10:21:55
 Re: DIESEL LEAK in reply to MSM, 08-26-2006 05:38:44
MSM THANK FOR YOUR REPLY CAN YOU EXPLAIN HOW DIESEL CAN GET INTO THE BACK AXLE OF MY JD 2650,as there is no problem with the engine oil, PERHAPS I'M BEING THICK MANY THANKS
