Tractor Talk Discussion Forum
Is there such a thing as a lawn mower salvage yard
Brokenwrench
08-25-2006 05:59:04
Hey All, Posted this question on the garden tractor forum but got no response. We have a 445 JD mower with a cracked hood. New hood from Deere is over $300. I was wondering if there is a source out there that would have a used or even aftermarket hood. Thanks in advance for any help
Brokenwrench
Leland
08-25-2006 21:43:01
 Re: Is there such a thing as a lawn mower salvage in reply to Brokenwrench, 08-25-2006 05:59:04
Fiberglass is easy to repair the trucking company I worked for kept about a 1/2 dozen rebuilt around ,and I have saw some really broken hoods repaired that looked better than new .
Brokenwrench
08-25-2006 18:30:53
 Thanks Folks!!! in reply to Brokenwrench, 08-25-2006 05:59:04
Thanks for all the replies. I`m gonna look into getting it fixed. I have a good body guy just down the road. Thanks again Brokenwrench
Ryan - WI
08-25-2006 16:32:43
My suggestion to you and anyone else who has questions on JD lawn tractors would be to visit Weekend Freedom Machines. That is the authority site on JD Lawn and Garden tractors. It also has a for sale and wanted section.
buickanddeere
08-25-2006 10:16:05
Used hoods that are not smashed or have been already repaired are rare and cost just about as much as a new hood. I've seen front bumpers added to more than a few lawn & garden tractors, usually after smashing the 2nd or 3rd hood.
glennster
08-25-2006 08:21:33
there is one in moody missouri, i cant rember the name, the have a couple hundred rider mowers.
Gerald J.
08-25-2006 08:07:00
There is one in Luther, Iowa behind an independent mower repair shop. Something as new as the 445 isn't likely.
And the odds are that if your hood is cracked all the rest in the world are unless you had something odd like a tree falling on it.
Gerald J.
Brokenwrench
08-25-2006 09:29:16
 Re: Is there such a thing as a lawn mower salvage in reply to Gerald J., 08-25-2006 08:07:00
Ya, this was an accident. I had the haybine parked in the corner of the yard. Dad was mowing and nosed in alittle too close and snap, a peice busted off the hood (fiberglass). It`s one of those cosmetic things, mowers in otherwise great shape. It just bugs dad to see that chunk missing. On the other hand it`s hard to shell out $300 + bucks to replace it. I don`t know much about fiberglass, but we have the broken piece. Can it be repaired??
Gerald J.
08-25-2006 09:43:41
 Re: Is there such a thing as a lawn mower salvage in reply to Brokenwrench, 08-25-2006 09:29:16
Fiberglass can be repaired. Its based on a resin, either epoxy or polyester and glass fibers put into a mold, often only a one sided mold. The same resin can put it back together and fill the gaps where it ripped and then a bit of sanding, filling and paint can fix it almost like new.
Gerald J.
MGTPa
08-25-2006 15:05:01
 Re: Is there such a thing as a lawn mower salvage in reply to Gerald J., 08-25-2006 09:43:41
Yep, like Gerald said, easy repair job. If you're not sure doing it yourself, take the hood to local body repair shop. They have the tools, materials, epoxy, & paint to do a professional job. You shouldn't even be able to tell where the piece was chipped off the hood when it's done. Lot cheaper then spending $300 for a new hood.
Coloken
08-25-2006 07:23:38
jdpuller or some thing like that I think. In Iowa. Been a while since I bought from him and I might have him mixed up with a regular here.
cj3b_jeep
08-25-2006 06:12:23
I see one advertised in the Farm and Dairy, our local weekly farm newspaper here in northeast ohio. I could check into it over the weekend and post the info on monday
brokenwrench
08-25-2006 06:53:12
 Re: Is there such a thing as a lawn mower salvage in reply to cj3b_jeep, 08-25-2006 06:12:23
Thanks, that would be great.
