Tractor Talk Discussion Forum
foam filled tires
fugly8n
08-22-2006 13:01:41
hi guys i live near cincinnati and want to get foam put in my tires i called the new holland dealer and they were no help anybody know where i can get this done thaks for all replies
mowr
08-23-2006 20:26:37
 Re: foam filled tires in reply to fugly8n , 08-22-2006 13:01:41
I don't mean to be a spoil sport but be sure to get plenty of seat time running on foam-filled tires in YOUR real-world conditions before you spend your hard-earned dollars on having this done. Beg, borrow or...well no, don't steal one to use for awhile, but once it's done, it can't realistically be undone. And you can't believe how back-breakingly bumpy a field (or unpaved driveway) is until you don't have AIR in the tires. Neither can you believe how absolutely helpless a tractor can be when the ground gets greasy (wet, snowy or ?) and the tires (with no air) can't conform to the surface. Or how lumpy the ride is on a smooth road after they've taken a set in the cold. Just one man's hard-learned experience.
IHFan
08-23-2006 03:30:29
Bluegrass tire Lexington Ky.
jc
08-24-2006 14:31:23
 Re: foam filled tires in reply to IHFan, 08-23-2006 03:30:29
Big-O in Owensboro.
iowa_tire_guy
08-22-2006 18:58:58
Go to a tire shop that deals in industrial and/or farm tires and if they can"t get it done they will know where you can.
glennster
08-22-2006 14:06:36
we had our skid loader tires loaded with a liquid urethane from the local fs ag dealer. they put tubes in the tires because the liquid sets and you have to cut the tire off the rim when they wear out. the tires wont go flat. i think it added 3 or 4 hundred pounds to each tire.
BigMarv1085
08-22-2006 16:25:24
 Re: foam filled tires in reply to glennster, 08-22-2006 14:06:36
I know that Gemplers had foam that you could buy and put in your tires.
