Tractor Talk Discussion Forum
Noisy Tractor/Tranny/Hitch? - Help!
Miss Kelly
08-22-2006 11:12:11
A few months ago, I purchased my first tractor, a Ford 9N. I have a question regarding the noises I hear whenever I lift an implement that I have hooked up to the 3-point hitch on the tractor: I hear squealing and/or knocking coming from the rear end whenever the implement is raised, or is in the air; this noise stops as soon as the implement is lowered - is this normal? If not, what can the cause of such noises be? Thanks!
souNdguy
08-22-2006 11:35:14
 Re: Noisy Tractor/Tranny/Hitch? - Help! in reply to Miss Kelly, 08-22-2006 11:12:11
That 60 year old scotch yoke piston pump likely has some wear and may knock a bit. Don't worry about it. When it stops knocking.. then worry.
90wt gl1 oil in the tranny vs utf oil will help it.
Soundguy
Miss Kelly
08-22-2006 11:53:24
 Re: Noisy Tractor/Tranny/Hitch? - Help! in reply to souNdguy, 08-22-2006 11:35:14
Thanks - I'll give that a try!
Turke Bros. Farms
08-22-2006 11:32:27
Unhook your implement and try to raise and lower the 3 point. does the noise go away?
Miss Kelly
08-22-2006 11:50:34
 Re: Noisy Tractor/Tranny/Hitch? - Help! in reply to Turke Bros. Farms, 08-22-2006 11:32:27
Yes, it does. Only when there is an implement on the hitch does the noise occur.
