Tractor Talk Discussion Forum
Good LOADER for 4020
raleigh
08-17-2006 17:51:52
What is a Good Loader for a 4020? It does not matter if its a John Deere or Big bend or somethig else. I just need to know what model numbers to search for.
in-too-deep
08-18-2006 10:22:40
 Re: Good LOADER for 4020 in reply to raleigh, 08-17-2006 17:51:52
The International 2000 Series loaer are built like a brick house. Don't know if they can be mounted on JD, but if they could,it'd be like having a dozer blade up front. Good luck.
Allan In NE
08-18-2006 10:48:17
 Re: Good LOADER for 4020 in reply to in-too-deep, 08-18-2006 10:22:40
I agree.
That's why nobody likes 'em.
When shopping for a loader, you want the lightest physical weight with the highest lifting capacity you can find.
Allan
Mike M
08-18-2006 07:35:28
Like others said the JD 148 and 158 I have a 158 on a 4020 and it does a great job. Lots of lift (about 4000 lbs.) and lots of reach. Which can get you into trouble too ! this is why I posted. You will NEED fluid in both rear tires as full as they put them and that is not still enough so we hang a model 115 rear blade on the back maybe another 1000 lbs. ? and this is just right !
I also think if easy on and off is what you need than maybe a loader from another maker or a newer JD one would be better. You have to unbolt some large bolts to get the 158 on and off. I always leave it on.
dej(JED)
08-18-2006 05:15:01
I have got an IH 2250 quik detach that would work well.
NcNE
08-17-2006 19:19:58
A recomendation I might add is a quick-tach loader. It makes it an awful lot easier to drop the loader if you want to do some field work or tractor maintenance.
Gerald J.
08-17-2006 19:17:34
The JD 48 and 58 were also used on the 4020. And every maker of loaders has several to work with the 4020. Its not a problem of there being few, its a problem of there being many.
I have a MF-236 loader on my 4020. Its almost strong enough to survive, though I've not broken the loader, just the buckets so far. It was too much loader for my MF-135 that it came on.
Gerald J.
Cliff Neubauer
08-18-2006 05:40:15
 Re: Good LOADER for 4020 in reply to Gerald J., 08-17-2006 19:17:34
The bucket's Massey used on those loaders were a joke. We had a 6' bucket on a 246 loader and it got rebuilt three times before I finally got fed up and built my own bucket for it from scratch. I used all 1/4" plate with several 1/2" wear strips under the bucket for extra strength as well as a gusset in the middle. We never had anymore bucket problems after I built this bucket and I even used it to pick up a 4,600lb grain head one time which our neighbor thought I would never get off the ground.
jack-iowa
08-17-2006 19:12:53
I have a 158 on my 4010 and it is the cats meow.
Strong sturdy you name it ,it is good.
las vegas
08-17-2006 18:45:39
I had a 158 JD loader with a 7 foot bucket. It was a great loader for the reach and the height. The 148 is shorter and closer to the tractor. You decide. The 148/158 loaders were incredibly strong and reliable...Even easy to get on and off with their "pivot arm" attachment system and stand!
Tim Shaw
08-17-2006 17:55:35
JD 148 would be a pretty good match.
