Tractor Talk Discussion Forum
International 434
Jacques Leblanc
08-17-2006 16:18:56
I bought a Inter 434 tractor equiped with gaz engine (BC144). It is supposed equiped too with a two stages clutch. When I fully depress the clutch, I am not able to engage the PTO, all gears seems to be in fonction. I adjust the clutch as mentioned in Operator Manuel, so with the pedal fully depressed, the PTO lever arm refuse to engage. To get the PTO,I am force to stop the engine, engage the PTO and restart the engine. I would appreciate to know what is the problem and how to resolve this. Once the engine running and the PTO engage, I can change easily first gear to second one but the PTO never stop even same I depress the clutch pedal.
Thanks in advance
Jacques
IH2444
08-18-2006 06:37:11
 Re: International 434 in reply to Jacques Leblanc, 08-17-2006 16:18:56
I had the same problem on my 2444.
I found that the bolts that opertae the second stage were very far out of adjustment. I adjusted them thru the inspection plate in the bottom of the clutch housing and all is well.
Of course it could just be stuck as well.
Hugh MacKay
08-18-2006 01:46:54
Jacques: I agree with Bob, but try running it awhile. When your pto is under heavy load, try putting clutch all the way down. Your mower should do it in heavy cutting. Could be the pto clutch stuck on shaft or it's presure plate. That might free it, if stuck. It may take several times and indeed a few days use.
If that doesn't work, you'll probably have to split the tractor.
Bob
08-17-2006 22:19:49
Either the PTO portion of the 2-stage clutch is stuck (the lined plate rusted in place), or it is out of adjustment, or it is damaged... (possibly the release fingers).
In any case, unless it is simply stuck, and finally breaks loose, the tractor will have to be split to see what's wrong, and to repair it.
Kenny Houser
09-26-2006 14:16:37
 Re: International 434 in reply to Bob, 08-17-2006 22:19:49
I have a 434 that I have been trying to sell.Everyone that looks at it wants to know what year it is,and how many horse power it is.Can some one help me out here.I don't have the ser# handy as I just found this site.It is a gas tractor,high&low range transmission,power steering{ that doesn't work}.
