Tractor Talk Discussion Forum
J.I Case Model 730CK with Draft-o-Matic Lift
Dust Commander
08-16-2006 03:27:35
I've had this old tractor for 15 years or so, but it's hard to get parts. Both the instrument panel serial number and the engine serial number plates were gone when I bought it. I'm positive there are ways to narrow down the serial number reasonably, but my dealer is uncooperative. For starters, I have both a correct and an incorrect Operator's Manual. The incorrect manual indicates it's good for a certain serial number and after, but the correct manual makes no such reference. At the very least, the dealer should be able to look up the publication number of the correct Operator's Manual and relate that to a range of serial numbers, but he says he only knows International parts, and not Case parts. He did eventually find the numbers and order tie rod ends for me, though.....
c hess
08-16-2006 10:04:23
 Re: J.I Case Model 730CK with Draft-o-Matic Lift in reply to Dust Commander, 08-16-2006 03:27:35
Go to old line Case dealers such as John Saeli or Binkly an Hurst if your dealer fools you around. Safe to say they would be able an glad to help you!!!! You will find parts that those others say they cant get are in fact avaible.
Dust Commander
08-16-2006 11:11:57
 Re: J.I Case Model 730CK with Draft-o-Matic Lift in reply to c hess, 08-16-2006 10:04:23
Thank you very much!!!
