Tractor Talk Discussion Forum
8N tractor with loader
ddscull
08-15-2006 10:06:41
would any one know how to Identify, name plalte , where that is and some visual signs,of a loader that was on my tractor 8N Ford when i bought it it has a front pump and fuild in the steel tubes. I think it is Derborn or Wanger but would like to know the model number
and for sure which one it is, name if there is a differance they look a like? any help?
Thanks ddscull
Nolan
08-16-2006 04:57:46
 Re: 8N tractor with loader in reply to ddscull, 08-15-2006 10:06:41
Even having a nameplate won't always get you too far. I had a Wagner loader on my Ford, the loader was a 9NM model as I recall. Something that I never found in any Wagner literature (what can I say, I'm a literature hound).
Not that it mattered anyhow, as Wagner parts aren't made, and you've got to go measuring things to figure out if replacement parts will fit.
ddscull
08-16-2006 06:57:13
 Re: 8N tractor with loader in reply to Nolan, 08-16-2006 04:57:46
Thanks for all the help,I can see that th loader is pretty well used. Thanks again ddscull
Tim B from MA
08-15-2006 19:52:56
I have an 841 with a Wagner loader. There is a name plate somewhere near the valves, but it was pretty well worn when we cleaned up the loader and painted it last winter. There are also name plates two on the "non-business" ends of the cylinders ( that raise and lower the boomi.e., on the backs of the cylinder housings)near your feet. They were buried in grease and dirt and were much better preserved. Those ones won't give you the model number, but I don't know that you need it. Generic hydraulic parts and couplings can be matched by numbers on the parts themselves or just by cylinder diameters, descriptions of seals and that sort of thing.
ddscull
08-15-2006 14:11:08
Thanks Old , i looked and could find a name plate. so ill ask you another question. what is the hole to hole on the cylinder and is the shaft a 2 inch , and one more when the bucket sits flat on the ground is the shaft all the way in and if not how much does it stick out?
Thanks ddscull
old
08-15-2006 11:55:35
The the loader I have on my 8N has a plate on the right hand side on the main frame just behind the main arm pivot. So if your sitting on the seat it would be just at arms reach when you where on the seat at about shoulder level. Theres a picture of the tractor in the web page, its the one with the backhoe
