Tractor Talk Discussion Forum
Charging 2 Batttery setup....
Jon (IN)
08-14-2006 06:46:35
If I want to hook up my battery charger to my tractor, which has a normal12v -2 battery parrallel setup, can I charge both batteries at once, without unhooking them? Or do I need to disconnect one and charge each one individaully?
Thanks,
Jon
Bob
08-14-2006 06:50:49
 Re: Charging 2 Batttery setup.... in reply to Jon (IN), 08-14-2006 06:46:35
If the batterys are in good condition, there should be no problem charging them in place, connected up.
After all, that is what the machines charging sysem does.
If one battery is weak or shorted, obviously it needs to be replaced, anyway. Actually, if one is bad, starting with two new batterys is the best plan.
