Tractor Talk Discussion Forum
Now I get to complain about Ferrel Gas...
Matt from CT
08-12-2006 11:51:15
At least I didn't buy anything yet...
Gas grill ran out while I was making lunch. No biggie...
First grill I've had, first time I ran out.
Out of curiousity, went to look up how much an exchange would be...
A noticed a comment from 2001 about Blue Rhino only having 17.5# in a 20# cylinder...
Looking at their website, the current picture...bottom of the label...
"Net Weight 17lbs"
Gotta wonder how many people notice there get a cylinder underfilled by 15% when they buy a Blue Rhino...
Grrrr...well, since I'd kind of like not running out of gas more often then necessary, I'll got get it filled properly!
Sid
08-12-2006 20:32:52
 Re: Now I get to complain about Ferrel Gas... in reply to Matt from CT, 08-12-2006 11:51:15
Remember that the water capacity is the total amount of water that the tank will hold. You stated your tank size was 47.6 pounds of water. That is the volume of the tank is about 5.75gals x.8=4.5 or about18.9 lbs of propane. Now remember that the OPD thingy is a float and it is the volume that shuts it off not the weight. Now remember that liquid (propane is a liquid) expands as it gets warmer. So a gallon as it becomes warmer becomes bigger. That is why pumps are calibrate to allow for temperature changes. And hopefully that explains why your weight came up a little light. So you saved eight dollars on the bottle and pretty well got about what you should have gotten in your bottle.
bill mar
08-12-2006 17:17:48
if nobody can legally fill it more than 80 to 85% you either have to look at the filled price and comparison shop for other "filled" prices,or see what everyone charges per pound or gallon.it still kills me that a 2X4 is not 2" by 4".how did that get started? one other thing that gets me is the 9/10 cent they tack on fuel prices at the pump. bill m.
Matt from CT
08-12-2006 18:57:04
 2x4 at least I understand... in reply to bill mar, 08-12-2006 17:17:48
And can get a true 2x4 if I go to the local sawmill and get an unfinished board.
They lose a 1/4" on a side to the planer.
I'm sure the modern lumbermills probably can cut them a smidge tighter and plane off a little bit...but they've always kept the nominal name to be the traditional unfinished dimensions.
paul
08-12-2006 22:58:17
 Re: 2x4 at least I understand... in reply to Matt from CT, 08-12-2006 18:57:04
Restoring an old barn this summer.
The new standard wood is smaller than the old standard lumber, which is smaller than the real old wood that is not planed.
It's getting worse. And they've gone from buzz saws to high-tech thin band saws, so obviously they are getting more pieces of smaller wood from the same log, and pretending it's some made up size.
Drop siding, for example, lost a 3/8 inch - somewhere.
--->Paul
BobMo
08-12-2006 17:08:32
I still don't understand your compliant. If its to high don't buy it. You only pay for what is put into the tank. Just accept that..... ...
Matt from CT
08-12-2006 19:00:03
 Re: Now I get to complain about Ferrel Gas... in reply to BobMo, 08-12-2006 17:08:32
I was more miffed if they had reduced how much gas they put in a standard size package.
Like the detergent companies and others do at the grocery store -- reduce the weight, keep the box the same at least for a while so people don't realize they're buying less.
I'm happy I remembered who filled them locally...it's been so long since last time I did one, all the places I used to go have closed or don't do it anymore!
I still want to know the reason for 17 pounds as the "max" they'll do...that just sounds low compared to the math for what the regs I've found so far say.
arlobenn
08-12-2006 15:59:51
Thank the goverment for the short weight. The new OPD valves will not let them put more than 17-18 lbs. in the tank. Isn't it nice that we are so well protected from ourselfs?
Matt from CT
08-12-2006 16:18:15
 I'll have to go do some more research... in reply to arlobenn, 08-12-2006 15:59:51
And look to see if I can find anything in the code books themselves...
The only thing I can find online is the standard, and where the OPD is supposed to kick in, is 80% of the liquid capacity.
On my tank, my 80% is 19.4#. Maybe it used to be 85%...that would get me 20.5#.
Filling these suckers to 17# is only 70%.
And that just doesn't make sense to me -- the safety factor for expansion is already built into the 80% number.
What part of the puzzle am I missing here?
JMS/MN
08-12-2006 13:56:03
Complain about what? That they filled your tank as they should, to 85%- to allow for expansion, so no one needs to go to your funeral? As far as price for a fill- they charge you by the pound, and different companies have different rates- just like with other products you buy.
CLW
08-12-2006 12:13:12
Matt, that may be becouse LP gas expands . My 33 gal tank on my 630 is to be filled with a max of 28 gal. for that reason.
Matt from CT
08-12-2006 13:14:29
 Ok, maybe I got a little huffy too fast :) in reply to CLW, 08-12-2006 12:13:12
Ok...
I did save $8 because I remembered who around here fills them today and they charged $12 v. $20 for Blue Rhino.
CAVEAT #1:
Weighing my cylinder a few minutes ago on a bathroom scale, they also only put in 17# (cylinder had a tare weight of 17# stamped on it, total was 34#).
CAVEAT #2:
That makes no real sense...
The current NFPA regulations allow you to fill to 80% of the capacity.
My tank has a Water Capacity ("WC") stamped on it as 47.6#, which you multiply by .51 to get the Propane capacity...which is 24.22# And that's the number you're allowed under the current NFPA regulations to fill upto 80% of.
24.22 x .80 = 19.38#.
Hmmm...
I'll even concede at some point in the past what we call a 20# cylinder could have legally been filled to 20#, and under today's standards the same nominal size has to be filled a little less. Don't know for sure, but could be...
But still weight is weight, and that cylinder is designed under today's standards to safely hold more than 19 pounds of propane, and it's only being filled to 17...
Unless there's something else I'm missing???
MSD
08-13-2006 09:59:05
 Re: Ok, maybe I got a little huffy too fast :) in reply to Matt from CT, 08-12-2006 13:14:29
Sounds like you thinking you should get a 19# fill for the same price as a 17# fill. You are paying for what you get. If you want more #'s per fill get a bigger tank.
Hoosier JD
08-12-2006 13:05:31
 Re: Now I get to complain about Ferrel Gas... in reply to CLW, 08-12-2006 12:13:12
I have understood the same thing. On my 500 gallon tank, the gas man will only fill it to approximately 400-425 gallons, which is about 80-85% to leave room for expansion and/or room to let the liquid boil and make gas. Mike
Hoosier JD
08-12-2006 12:45:23
Gerry Gallo
08-12-2006 12:54:04
 Re: Now I get to complain about Ferrel Gas... in reply to Hoosier JD, 08-12-2006 12:45:23
I was called in to a manufacturing facility once where one of the huge propane tanks was overfilled. The tank was about 8' in diameter and 50' long. The whole end came off and caused sparks when it hit the concrete, thus sending the rest of the tank through the yard of the facility like a rocket. It was quite a sight to see. It gave me a healthier respect for safety as it pertains to propane.
