Tractor Talk Discussion Forum
1948 Farmall Cub - Exhaust manifold overheating/sm
Dave from York
08-11-2006 07:00:27
I've been having power drop off problems on my 1948 Farmall Cub. Spark Plugs have been replaced, and I just now replaced the distributor cap and spark plug wires, because they were pretty badly corroded. I have a condensor replacement, but haven't installed that yet-kind of intimidated by that repair right now. Anyway, after I installed the wiring, which went without problems, I replace all (5) one at a time (4 plugs + main). I know from the doc that the firing order is 1-3-4-2, and I'm assuming the cylinders are numbered sequentially 1 to 4 from front to back(can someone verify 1-to-4 front to back please. If I trace the wiring from the distributor cap starting at the top (1) position, the spark plug wires run 1-3-4-2. Now my concern:
When I crank start the tractor (battery needs replaced), it fires up and runs fairly smooth. After about 5 minutes, I notice 'fumes' or 'smoke' or thin, veiled vapors coming up from the engine's exhaust manifold up the outside length of the exhaust pipe (I have a vertical exhaust). Is this gasoline vapors that haven't been ignited and will they eventually ignite while running the tractor? I haven't seen any doc on this condition and how to correct it. It never did that before. I just think maybe something is not right with the firing order. I had removed the rotor once when I found the old distributor cap was corroded, but I thought I put it back in place the way I had found it, but I guess it's possible the teeth on the underside of the gears my not be exactly right. When I had removed it the one time, I had the tractor in gear so that nothing would move, because I was scared. I was trying to figure out how to replace the condensor. Is this thin wispy vapor problem the result of a timing problem? Please advise when you can...this is beyond me.
I am not a mechanic, but I need to cut grass-now hay-soon, and I need my baby back in good health.
Thanks ahead of time,
Dave Rhan
(717) 541-7176
Steve Moyer
08-11-2006 12:19:25
 Re: 1948 Farmall Cub - Exhaust manifold overheatin in reply to Dave from York Haven PA, 08-11-2006 07:00:27
Go to the Farmall Cub site, great knowledgable people over their they will help.
85_Ranger4x4
08-11-2006 10:26:18
You could be burning the paint of the manifold and/or exhaust pipe too. It is a natural thing that you can't do much about, and it should stop when it is burnt off.
ribbitt
08-11-2006 09:09:57
You may just be seeing heat radiating from the manifold and exhaust pipe, causing the adjacent air to heat up, especially if the air is calm. This changes the density of the air, causing it to "shimmer", like a mirage. But it's always a good idea to check the timing to make sure it's correct.
dave from york haven
08-11-2006 08:34:17
How do I check the timing? Where can I go to read up on this?
Bus Driver
08-11-2006 08:35:55
 Re: 1948 Farmall Cub - Exhaust manifold overheatin in reply to dave from york haven, 08-11-2006 08:34:17
Binder Books has all the CUB manuals. Definitely get the owner's manual. Binder has website.
08-11-2006 08:50:46
 Re: 1948 Farmall Cub - Exhaust manifold overheatin in reply to Bus Driver, 08-11-2006 08:35:55
addressed really to anyone...I did not have the Owner's Manual, so with limited funds, I did purchase the Service Manual...is there any noteworthy differences between the two?
Bus Driver
08-11-2006 08:34:16
Is the cooling system properly filled? If the coolant level is even slightly too low, NO COOLANT CIRCULATION will occur. You may be observing a general overheating problem.
08-11-2006 08:36:41
 Re: 1948 Farmall Cub - Exhaust manifold overheatin in reply to Bus Driver, 08-11-2006 08:34:16
the radiator was a bit low...I filled it up...I'll check to see if that does the trick...do you also think there could be a timing retardation going on?
Don L C
08-11-2006 07:59:21
Check the timming, it sounds like the timming is retarted..... this will cause the manifold to get red hot..... .
