Tractor Talk Discussion Forum
Fencing question....
Dachshund
08-09-2006 15:15:59
Any of you fence gurus out there ever use a wood post for a cross brace? I have been using 2" pipe, but have run out! I can go out in the "back 40" and cut hedge posts all day long. I can also come up with 4" diameter limbs that could be used as braces instead of pipe. Any ideas? I have about 3/4 of a mile to do here this Fall and am trying to get ready!
Dachshund
08-10-2006 12:47:32
 Re: Fencing question.... in reply to Dachshund, 08-09-2006 15:15:59
Ok, thanks for the replies! Since I can't afford any pipe, it's looks like I'm gonna try the wood braces this go-round! Thanks for the help!
2t2@IA
08-09-2006 20:46:35
Don"s reply is good.
My father did some fencing in 1913 with osage orange posts. They are still standing strong. Of course they are not real easy to work with.
Dachshund
08-10-2006 01:54:18
 Re: Fencing question.... in reply to 2t2@IA, 08-09-2006 20:46:35
Yeah, I've built a lot of fence with Hedge posts! There are some on the old place that my Great Grandfather put in the ground in the 1880's that are still going strong! I just don't have any more pipe and can't afford to buy any - just wondering what everyone thought about using a wood cross brace! Thanks!
John A.
08-09-2006 20:35:35
Dachshund, Fence ?s are just like, which oil is best? And like the ones the Redneck Comedy Tour....I Belive,,,,,I Belive.....You already know the answer to your ? before you asked it!
I Would Not use A Wood Post as part of a H-Brace. Not under any circumstances! You are going to the trouble to put in new heavy corner post use the pipe as the cross member.
Only Rookies use a wood cross center member in this country. In 5 yrs it will fall out, and the fence will slack, Period. Just drive around the roads and look at the somewhat new fences that are slack and the H-brace has slipped out
I will probably incur the Rath of a thousand mad farmers who have use wood all their lives and haven't lost one yet.
Most guys have gone the all steel pipe corners all welded together. Most post are 3.5 to 4.5 ft in the ground, concreted in with 2 bags of sacrete.
Go get some pipe at a salvage yard, your scrap pile, you will be more happy with it and satisfied too.
2 3/8 pipe can be all day long for $1.50. ft. or less. So if you need 4, 6ft section it will be less than $40 for all ot it. So as I said above, Don't shoot yourself in the foot by short changeing yourself on such a critical, but often overlooked part of your fence.
Later,
John A.
BobMo
08-09-2006 17:36:39
Recently I've been using them treated landscaping poles. I'm 65 and think they'll out live me. I'm not building any fence for my grand kids..... ...
J.C.H.
08-09-2006 15:43:04
Here in Az. the Horse people are going to Cedar Posts with Barbless Wire on Steel posts. Gate and Cornor Posts are cedar with two posts either side of a Gate and a Horizontal Post cross tied with twisted # 9 wire. Posts are about 6" O.D. In between the Steel Posts about on 12" enters woven between the Barbless Wire in a vertical position are abour 2-3" Cedar support posts. They don't appear to be imbedded in the dirt just as a barrier so a Horse won't try to walk through the wire I guess. All wood parts are Cedar.It Is becoming quite popular versus the Sucker Rod and Pipe Fences we commonly see. The working Ranches still use Barb Wire with any kind of Limb or Branch from any kind of tree available to support the Barb Wire. Posts are real hard to drive in some of the places where the Ranchers have to put fences so the Steel line posts are some times far apart. Now a real wicked Fence is one the old timers erected and they are still to be found around here. They strung 3-4 barb wires and then laced Ocotilla branches thru the wire real close together. Well the Ocotilla usually would start new growth and would renew itself and "Boy Howdy" is it wicked. First "Spanish Sabre" Fence I ever saw I almost ran head first into it with my Quad before I realized what it was.I have a lot of respect for any thing planted in a row now.
don in oh
08-09-2006 15:34:32
thats all i ever use, i like to drill a 1/2" hole
on the top of both posts cut a piece of steel rod
long enough to drive it in the cross post a few inches, then tighten with the anchor wire.
GregC
08-09-2006 15:31:22
Lot's of guys do it around here. Can't see much problem when you're using hedge.
