Tractor Talk Discussion Forum
My big Balls
Nebraska Cowman
08-08-2006 16:08:29
So I did a little searching too and the 6 pound Mountain Howitzer used by the military to fight indians used this size ball. As there were a lot more indians in this area than rock quarries, it would be my guess that is what they are.
third party image
JMS/MN
08-09-2006 10:31:26
 Re: My big Balls in reply to Nebraska Cowman, 08-08-2006 16:08:29
Back in '67 my hold baggage arrived home from overseas two months after I did. Scared the heck out of my Mom when I was going through it and said, "Oh great, here's my cannonball!". Picked it up on a beach.
Rauville
08-09-2006 07:21:01
I would think that cannon balls were iron vs. steel for some of the other uses that have been listed.
I can almost hear Bob Wills and "Big Balls in Cowtown" playing in the background.
Chad Franke
08-09-2006 08:57:38
 Re: My big Balls in reply to Rauville, 08-09-2006 07:21:01
Ok, I'm from a bit younger generation, my thought was AC/DC when I read the title...
Matt Smith
08-09-2006 05:07:27
Did anyone else have a Jerry Clower flashback when they read the title of this thread?
37 chief
08-08-2006 18:17:41
Did you find the balls in your field? Stan
Matt from CT
08-08-2006 16:38:23
Sure those aren't missing from the tractor Allan got the haybine stuck with???
BobMo
08-08-2006 16:19:24
You may be right or it could be that after a really bad winter out there thats the reason there aren't any monkeys in your area.
Nebraska Cowman
08-08-2006 16:30:05
 Re: My big Balls in reply to BobMo, 08-08-2006 16:19:24
We only have small monkeys here. not much in the way of summer fruit some years and they go hungry all winter. Now you get down around Orleans Nebraska in the "banana belt" and the monkeys are bigger there.... but I don't think even they have iron balls.
third party image
Rod in Smiths Falls, ON,
08-08-2006 17:29:40
 Freeze the balls off a brass monkey? in reply to Nebraska Cowman, 08-08-2006 16:30:05
In answer to the question no one asked, at 28 degrees Fahrenheit the balls freeze off a brass monkey.
On British ships of war the brass monkey was a cast frame to hold a pyramid of cannon balls in place on the deck. The differential in shrinkage between brass and iron would occasionally combine with rough seas to produce great confusion on the deck, and became a frequent reference point in conversations about the weather.
sammy the RED
08-08-2006 19:21:55
 Re: Freeze the balls off a brass monkey? in reply to Rod in Smiths Falls, ON, , 08-08-2006 17:29:40
That is a myth.....Not true.
Joe (Wa)
08-09-2006 00:27:36
 Re: Freeze the balls off a brass monkey? in reply to sammy the RED, 08-08-2006 19:21:55
Sea story AKA "this is no sh!t"
Most sailing ships had a cannon for protection. Cannon of the times required round iron cannonballs. Ready use cannonballs were stacked in a square-based pyramid next to the cannon. The top level of the stack had one ball, the next level down had four, the next had nine, the next had sixteen, and so on. Four levels would provide a stack of 30 cannonballs.
The only real problem was how to keep the bottom level from sliding out from under the weight of the higher levels. To do this, they devised a small brass plate ("brass monkey") with one rounded indentation for each cannonball in the bottom layer. Brass was used so the cannonballs wouldn't rust to the brass monkey.
Due the difference in metal composition and mass, the brass contracted in size faster than the iron. As it got cold on the gun decks, the indentations in the brass monkey would get smaller than the iron cannonballs they were holding. If the temperature got cold enough, the bottom layer would pop out of the indentations spilling the entire pyramid over the deck. Thus it was, quite literally, "cold enough to freeze the balls off a brass monkey."
sammy the RED
08-09-2006 20:30:54
 Re: Freeze the balls off a brass monkey? in reply to Joe (Wa), 08-09-2006 00:27:36
According to the United States Navy Historical Center, this is a legend of the sea without historical justification. ..... ... The Navy says there is no evidence that the phrase had anything to do with ships or ships with cannon balls.
FarmallBob
08-09-2006 16:07:51
Hey Joe,
My dad always used that expression "It cold enough to freeze the balls off a brass monkey", but I don't believe he knew any more than I did where it came from. Thanks for clearing it up. Now I can use the expression and not feel bad about hurting someones feeling.
Bob
