Tractor Talk Discussion Forum
B FARMALL WIRING
ANDREW of SNOW
08-07-2006 14:23:01
VOLTAGE REGULATOR HAS 4 TERMINALS "L" "F" "BAT" "GEN"
LIGHT SWITCH HAS 4 POSITIONS "L" "H" "D" "B"
I PUT F TERMNIAL ON REG.TO F TERMINAL ON GEN. I PUT GEN. TERMINAL ON REG. TO " A" TERMINAL ON GEN. I PUT BAT. TERMINAL ON REG.TO AMP GAUGE. I DONT KNOW WHERE "L" TERMINAL GOES FROM REG.
Bob
08-07-2006 17:25:23
 Re: B FARMALL WIRING in reply to ANDREW of SNOW HILL N.C., 08-07-2006 14:23:01
If the link below doesn't work, cut and paste this link into your browser for a factory wiring diagram:
Link
Legend for Key #'s...
Link
John T
08-07-2006 14:46:22
Andrew, When using a 4 pole VR with the (L)oad terminal, the L terminal is what feeds hot battery voltage to all the loads such as lights and igition via the BAT input terminal on those switches. On a 3 pole VR that doesnt have the extra 4th L terminal, those loads are fed voltage from the ammeters Load terminal, being the same ammeter terminal that wires down to the BAT terminal on the VR. Sooooo o the ammeters load terminal wires to the BAT terminal on that VR and then a wire from its L terminal is what feeds input voltage to lights and ignition switch(es). Its possible to make a 3 pole VR work in place of a 4 or vice versa, its just a matter of where loads like lights n ignition receive their voltage from, the load side of the ammeter on a 3 pole VR system but the L terminal on the 4 pole VR system.
To answer your question, the L terminal wires up to the dash to power up the switches (lights and/or ignition) on their BAT input terminals.
John T
K-Mo
08-07-2006 14:40:19
Your light switch is for using a generator with a cut-out relay. The "L" & "H" function would connect to the "F" terminal of the generator for choosing a High or Low charging rate. Since you have a regulator installed you can use the "L" terminal to power the headlights. This will provide additional generator output when the lights are on. You will not be using the "L" & "H" function of the light switch. You will still use the "B" (bright) & "D" (dim) for the headlights.
K-Mo
