Tractor Talk Discussion Forum
JD 5020 injuction pump
37 chief
08-05-2006 23:47:54
The last time I used my 5020, the injuction pump started making small plactic pieces, plugging up the return line check valve.I was able to finish the job. I probably wouln't be using it anymore, as all the large fields are being split up around here. I would like to sell it, but want to fix the pump problem. I can have it rebuilt for around 600.00, or what are the chances of finding a good used pump probably for a lot less? I bought a used pump for my MF about 6 years ago, and it is still going strong. Decision time, Stan
farmerrichard
08-06-2006 19:27:56
 Re: JD 5020 injuction pump in reply to 37 chief, 08-05-2006 23:47:54
Can you tell me where you live? What Horse power this is? Does it have a cab? And if your interested in selling it how much?
37 chief
08-06-2006 20:08:46
 Re: JD 5020 injuction pump in reply to farmerrichard, 08-06-2006 19:27:56
I live in Southern Calif,probably further than you want to haul the thing. As for the horse power it must be somewhere around 130. no cab. Stan
Bob
08-06-2006 00:09:32
The "O" ring and seal kit for that pump is less than $30.00. The Stanadyne kit used to include the governor damper ring, now it doesn't, but some aftermarket kit MAY include it. Stanadyne wants you to upgrade to the improved weight carrier for $50.00 or more, which is a good idea. However, it ran for thousands of hours with the original setup, and will run for thousands more with the damper ring replaced with the original style.
Anyhow, if the pump is otherwise OK, if you can find an old-timer that used to work on these pumps when they were serviced at the dealerships, rather than exclusively at $$$$ pump shops, he can put the seal and ring kit in for the $30.00, and a couple hours labor.
Obviously, he won't be able to calibrate it on a pump stand, but the important adjustments are not disturbed but installing the damper ring.
Just don't brag in your "for sale" ad that the pump is "new" or "completely rebuilt".
