Tractor Talk Discussion Forum
gravley mag timing
chris sweetland
08-04-2006 10:35:34
ok boys i screwed up got excited to get my 59 gravley li running and pulled the mag too fast and forgot o make timing marks so i could line it back up now i cant get the darned thing lined up so can i have some tips on getting it back on time thanks chris
Bret4207
08-04-2006 14:09:52
 Re: gravley mag timing in reply to chris sweetland, 08-04-2006 10:35:34
Basically the piston is 3/8" BTDC and you line the marks up from there. Some require a little tweaking and if it was put together backwards it'll be 180 degrees out and fire through the carb.
teej
08-04-2006 10:43:00
Go to www.oldgravelys.net
There you can download service manuals, repair manuals, operator manuals, everything you'll ever need for the machine, including parts lists free, no charge. Also, many of the attachments are there as well.
You'll find plenty of information on how to re-time the magneto to your engine. Gravely used 3 different magnetos manufacturers over the years, timing marks are a little different, but the basic procedure is the same for all of them. You'll find great step by step instructions there.
old
08-04-2006 11:22:34
 Re: gravley mag timing in reply to teej, 08-04-2006 10:43:00
I jsut tried that web address and it didn't work. Maybe I did something wrong or ??? It would be nice if you could post it in the optinal link url at the bottom so maybe it would work. I know I sure could use some info on a model L I have
teej
08-04-2006 13:02:18
 Re: gravley mag timing in reply to old, 08-04-2006 11:22:34
I did post it in the optional link url spot. Why it doesn't show up, I don't know. Its happened to me before that it doesn't show up all the time, so, I type it above also, just in case.
I'll put it in again.
Glen in TX
08-04-2006 12:11:11
Worked ok for me.
