Tractor Talk Discussion Forum
mf165
stormy too
08-02-2006 03:29:16
I have a mf-165-gas -6speed hi-lo tranny live pto am going to run a brush hog, do I need an override clutch on the pto shaft?? Thanks Stormy
Don-Wi
08-02-2006 10:39:32
 Re: mf165 in reply to stormy too, 08-02-2006 03:29:16
If your 165 has a dual stage clutch, it has no PTO brake, it freewheels on it"s own so you can just hook it up and go. I always idle the engine down before disengaging the pto no matter what I run.
Donovan from Wisconsin
GarryinCT
08-02-2006 03:49:40
I have a 165 with independent pto and the pto brake is small so to give it a (Break) I do use a
override clutch.
stormy too
08-02-2006 04:55:39
 Re: mf165 in reply to GarryinCT, 08-02-2006 03:49:40
Thanks for info Just bought this 165 gas any more tips pro or con will be welcome thanks stormy
Crem
08-02-2006 17:24:04
 Re: mf165 in reply to stormy too, 08-02-2006 04:55:39
If you have independent PTO, be sure that you idle the engine down before before you engage it. I was mowing with mine and the PTO jumped out of gear. I re-engaged it while moving without idling it all the way down and the sudden engagement broke a gear in the tranny. It is hard to ease it in while moving in a bumpy field. Anyway I had to tear the tranny which has multipower, almost all the way down to replace the gears.
JDknut
08-02-2006 03:41:18
No., not if the PTO is live or independent.
