Here's the specs for the 40 horse, 3 gal hy pump, 12 qt cap. Looks pretty light duty to me. You get what you pay for. FT404 FEATURES Drive System 4 x 4 Power Steering Yes Hitch 3 point, category 1 Cab No Heat A/C No ENGINE Model SL3105BT Type Diesel Gross Hp 40 Cylinders 3 Rated Engine Rpm 2200 Cooling System Water/Anti-Freeze Glow Plugs YES Bore x Stroke, in. 4.13 X 4.33 Displacement 105 X 110 TRANSMISSION Speeds FWD/REV 8/4 Min / Max forward speed, mph 1.51 / 19.81 Clutch Type 10 in Dry Clutch Operation Single or Dual Shuttle Shift NO POWER TAKE-OFF RPM Range Lower/Upper 540/1000 Shaft Size � Spline 1 3/8 � 6 spline HYDRAULICS Pump Type N/A Model CBT-E310FL3 Flow - GPM 3.00 Working Pressure 2320 3 POINT HITCH Category 1 Lift Capacity at 24� SAE 1506lbs TIRES Tread Design Agricultural Front Size 8.3 - 20 Rear Size 12.4 x 28 BALLAST WEIGHTS Front 317.46 Rear No FLUID CAPACITIES Fuel Tank (Gal.) 10.00 Engine Oil (Qt.) 7.4 Front Axel (QT.) 7.4 Gear Box (QT.) 28.5 Hydraulic (QT.) 12.7 Coolant (Gal.) 2.5 DIMENSIONS Length 138.3� Width 68.9� Height (top of Exhaust) 83.3 Height (top of Cab) N/A Weight 4585lbs
