Tractor Talk Discussion Forum
Where to find 3 5/16 x 33 solid shaft
Tyler-MO
07-25-2006 11:48:33
I'm trying to repair a two-way integral plow that uses a 3 5/16" diameter x 33" long solid steel shaft that the plow pivots on. The original is broken and I need to find a substitute for it.
I intend to use an tractor rear axle shaft for this purpose. Can anyone out there tell me of any tractor that used this size axle shaft (it can be longer than 33" but not shorter).
Thanks for any help provided!
Tyler in Missouri
wdtom
07-25-2006 18:33:57
 Re: Where to find 3 5/16 x 33 solid shaft in reply to Tyler-MO, 07-25-2006 11:48:33
I don't know how sizes run in that range, buy finding 3 5/16 may be a problem. You might have to get say 3 1/2 and turn it down. I would think it would be easier to find 3, 3 1/4, 3 1/2 etc. Especially if you are trying to find it cheap.
Joe M(GA)
07-25-2006 17:02:28
hydraulic shop?? maybe out of a bad or bent rod?
Fred Martin
07-25-2006 13:14:40
If the shaft your replacing is cold rolled steel and it broke maybe you ought to consider medium carbon or high carbon steel. Just a thought, but might be cost prohibitive. Fred OH
Steve from Arkansas
07-25-2006 12:06:13
Where in Missouri are you? My son works at the Missouri Forge in Doniphan near Poplar Bluff. They forge parts from round stock. Might have what you need.
Tyler-MO
07-25-2006 12:30:12
 Re: Where to find 3 5/16 x 33 solid shaft in reply to Steve from Arkansas, 07-25-2006 12:06:13
I'm near Cape Girardeau...about 1hr from Poplar Bluff. Could you find out if they have 3-5/16" coldroll steel?
Thanks,
Tyler-MO
Steve from Arkansas
07-27-2006 06:30:51
 Re: Where to find 3 5/16 x 33 solid shaft in reply to Tyler-MO, 07-25-2006 12:30:12
My son says his company will not sell any of their metal, but he thinks there may be another place there that would. Will check some more.
Steve from Arkansas
07-26-2006 08:04:07
I'll have my son check.
