Tractor Talk Discussion Forum
Farmall V-8
Cory A.
07-24-2006 16:42:35
I am going to try to put a chevy 305 v8 into my farmall h. What are some problems I might run into? Do I have to make a plate to put in between the motor and transmission? I hope everything will work out ok. Thanks for any help!
Cory
jimNCal
07-25-2006 19:32:15
 Re: Farmall V-8 in reply to Cory A., 07-24-2006 16:42:35
Go for it. I saw a Super M with an International V8 in it at the last show in Tulare, CA. Only tractor I saw worth sitting/posing on for a photo. (I ain't all that photogenic anyways). The old-timer that owned it had every right to be proud. It was absolutely beautiful. Got me to thinking.....
Cory A.
07-25-2006 17:34:08
The only reason I am using the 305 is because I happen to have one laying around. I suppose I could put an electric water pump on it to help with the cooling. Its a strong motor and I have faith in it. If I had a 283 or a 327 I would use it. I'm not quite sure if I'll have to move the frame rails out a little more. Well thanks for the help! Cory
Jimmie James
07-25-2006 16:15:43
Why?
Robert in W. Mi.
07-24-2006 21:58:25
third party image
V8's in tractors are pretty common these days.... I see one or two at every show i go to anymore, and an ocasional one along the road too...
Here's a V8 powered SM.
Robert
Gerald J.
07-24-2006 18:43:03
You will probaby have to make that plate.
You will have cooling problems. The automotive water pumps expect a higher speed operation than hooked to a tractor transmission.
Gerald J.
Don L C
07-24-2006 18:12:15
WHY a 305, that is not the best v8 GM ever built..... a good old 265, 283, 327 would be a better choice..... If you must use the 305, change the cam and lifters, that was the weak point.....a RV grind would be a good choice..... Don
Roy Suomi
07-24-2006 17:56:50
Anything can be done...I once saw a 348 or 409 Chev in a big IH..It was awsume..... Very distinctive valve covers.. 8 " zoomie " pipes.
