Tractor Talk Discussion Forum
Starting
Ronald C. Chapp
07-24-2006 05:21:18
I have Ford 4000 tractor year not sure. When I try to start it will start but when I let go of the key after it starts it shut off. Ron
IH2444
07-24-2006 05:27:17
 Re: Starting in reply to Ronald C. Chappell, 07-24-2006 05:21:18
A gasser ?
If so then check trhe ballast resistor fior the coil , if it has one. Many gas engines have a ballast resistor to the coil for running, but bypass it for hotter spark when starting. If not a gasser, then I would suspect the ignition switch.
