Tractor Talk Discussion Forum
OT-F150 steering
Iowa Leonard
07-19-2006 18:39:46
My new used 1990 F150 has a loose steering gear box and after asking the mechanics to fix the wander problem, they put in $400+ of ball joints and it is worse! I have never, on the many used cars and pickups I have owned over the last 50 years, ever had to adjust or replace the steering "sector". Any way of tightening it? I wish I had my 88 Siverado with 270,000 on it back, now.
xragman
07-20-2006 11:58:48
 Re: OT-F150 steering in reply to Iowa Leonard, 07-19-2006 18:39:46
If this truck has power steering , check the frame closely. some people run the steering to the stops often ,whitch tends to crake frame.
Vern-MI
07-19-2006 19:44:52
Adjust the center screw on the sector cover. Place the gear in the center of its travel with the wheels pointing forward. Loosen the center screw locknut while holding the screw itself agaiinst rotation. Once the locknut is loose and backed off snug the screw down. This pushes the sector teeth down into the ball nut teeth. Once it is snugged down loosen it 1/4 turn. Then with the screw held against rotation tighten the locknut. Check to make sure that the gear does not bind after this adjustment. That is the best you can do. Any additional freeplay has to be worn shaft, worn bushings, worn gear teeth, etc.
Check to make sure that the flex coupling (rag coupling)in the connecting shaft from the steering wheel is not all shot and loose. It is relatively easy to replace.
Make sure the bolts that hold the gear to the frame are tight and that the frame is not cracked at that location.
Check to make sure that the pitman arm is firmly attached to the lower end of the sector shaft.
The input shaft should not move in and out of the gear box itself.
Finally check the tie rod ends to make sure they are not all loose and shot. Check the drag link and the idler arm for looseness in both the side to side and up and down directions. I would have thought that the garage where you had the ball joints replaced would have done all this but in this day and age you are lucky to find a decent doctor let alone a mechanic
Iowa Leonard
07-20-2006 04:50:12
 Re: OT-F150 steering in reply to Vern-MI, 07-19-2006 19:44:52
Thanks, I will give it a go.
