Tractor Talk Discussion Forum
Paint and Assembly
Stan(PA)
07-19-2006 14:31:08
I know a lot of you guys paint in pieces, and then assemble, so my question is this...
Engine to bellhousing (and other places), the connection must be metal to metal for ground, right? How about under the motor mounts? Do you use a dielectric grease at these points, or just bolt together with bare metal? Thanks in advance... Stan
B-maniac
07-19-2006 18:49:27
 Re: Paint and Assembly in reply to Stan(PA), 07-19-2006 14:31:08
Depends on the intended use of the tractor.The grease is an excellent idea (sparingly). A show tractor should be bare but dry.That grease will permeate out of that joint forever collecting dust,and depending on the type of paint,may even cause paint failure over time. Also, these tractors are not out in the weather enough for rust to ever permeate into these joints.Working tractor,grease them.
Stan(PA)
07-19-2006 19:03:57
 Re: Paint and Assembly in reply to B-maniac, 07-19-2006 18:49:27
Thanks. That"s exactly the info I was looking for.
