Tractor Talk Discussion Forum
Nasty, Nasy, Nasty Job!
Allan In NE
07-18-2006 19:12:04
Hi Guys,
After supper, I ran out to the farm and yanked these raddle bearings out.
Now boys, I know this is a shut-type ordeal, but don't ya think we've missed a scheduled maintenance somewhere along the line?
Trouble is, the bearings are still okay. If we would have just taken the time to adjusted that chain when necessary.
Did I mention that this is a really dirty undertaking? :>(
Allan
third party image
CBL
07-19-2006 12:04:40
 Re: Nasty, Nasy, Nasty Job! in reply to Allan In NE, 07-18-2006 19:12:04
Hi Allen, been reading about your F2 with much interest. I bought a new F2 Corn Plus in 1978. I had it until 2002 when I sold it. Had around 3600 hours at that time and is still going strong. In the years I had it I only replaced those rollers once. I ran the chain fairly loose so it didn't cut the rollers. Had the 4 cyl turbo intercooled engine, it was the most economical engine I ever owned but was harder to start tham the IH german diesels. Rollers are a bear to remove and replace and a shower sure feels good after. Good luck they are a good solid machine.
MidMiGene
07-19-2006 06:46:00
Allan, I have an F2 and I don't think I've ever seen those bearings. Would you mind taking a pic of where they are located in the machine. Thanks, Gene
Allan In NE
07-19-2006 07:15:15
 Re: Nasty, Nasy, Nasty Job! in reply to MidMiGene, 07-19-2006 06:46:00
Hi Gene,
They are right behind the raddle cleanout door at the otter edges and "just inside" the housing. They are the bearings that the lower end of the chain rides on and they incorporate the chain tightener on the outside of the feeder housing.
They are a real bear to get at. Have to lock the header in the up position, pull the cleanout door and "squeeze" yourself up into that small little space behind the concave door, with no light, to work on the darned things.
It is far easier to unhook the chain to get 'em out of there, but they will come out with the chain in place if you hold your mouth just right.
The only difficult bearing to get at on a Gleaner.
I'm used to running the machine in dry edible beans, which translates into running a heck of a lot of dirt thru the combine and these bearings have to be checked yearly under these conditions.
Allan
third party image
MidMiGene
07-19-2006 07:40:07
 Re: Nasty, Nasy, Nasty Job! in reply to Allan In NE, 07-19-2006 07:15:15
Thanks Allan. If you happen to be in Michigan, Mine probably need lookin' at.
MN Bob
07-19-2006 06:30:08
Allan; Looks like your right again, a little pre-ventive maintenance goes a long way. My neighbor just had prostrate surgery so I was helping him and he said he had to fix a disc. One look and I ask if he had ever greased or adjusted it at all. It had not been assembled right when he bought it new, and it took several hours, welding and grinding, and machining a couple spacers to get it going. Lack of care. Bob
Allan In NE
07-19-2006 06:38:28
 Re: Nasty, Nasy, Nasty Job! in reply to MN Bob, 07-19-2006 06:30:08
Yes Sir,
I learned a long, long time ago that the "hook on and go" approach is a recipe for disaster every time.
I usually spent way more time getting ready fer a job than the actual job itself. Just works out better in the long haul. :>)
Allan
Allan In NE
07-19-2006 06:44:57
 Re: Nasty, Nasy, Nasty Job! in reply to Allan In NE, 07-19-2006 06:38:28
The real kicker is that this machine appears to have a fairly new raddle chain and it was running on those old bearings.
Kinda think that they are the original bearings too.
Don't see any signs of the ol' gizmo running in the dirt like it was around beans.
Allan
Allan In NE
07-19-2006 07:24:53
 Re: Nasty, Nasy, Nasty Job! in reply to Allan In NE, 07-19-2006 06:44:57
I'm heading out there now to put the new ones in and will take my camera to get a view from up inside that monster.
Allan
paul
07-18-2006 23:59:37
As soon as that lip wears off the one completely, it will run a long time on an orange cornhead yet for the miles of chain under there.
--->Paul
Don L C
07-18-2006 21:30:24
Not only did they miss a greasen,but they cause heat..... ...now is a good time to remind our selves to blow that dust and dirt off the bailers ans combines,to ptevent fires..... ..read above Gary lost his haybailer..... Don
R.J.
07-18-2006 21:10:46
Allen you are right one dirty job. Have done that a couple times over the years. Never did like to lay under there no room can hardly set up
then bump head.
R.J.
doogdoog
07-18-2006 20:58:07
Aloha, It does look a little worn. LOL
Mahalo,
doogdoog
