Tractor Talk Discussion Forum
calling old or RickB
jughead 2
07-17-2006 18:45:06
The cylinder that opens and closes the gate on my round baler is leaking (as old you know). The question how does one remove the cylinder from the baler to repair it. Does it need to be hooked to the tractor or can it be done seperate. Thanks
old
07-17-2006 19:05:44
 Re: calling old or RickB in reply to jughead 2, 07-17-2006 18:45:06
Don't know if I did it the right or wrong way but, what I did was with it closed and no/zero preassure on the hyds I just removed the cylinder. You may have to undo the quick connects and then hit the ball to make sure you have no preassure but with the way my cylinders where leaking it didn't need to be done. Now if your working on the cylinders on a NH 850 or one like it there is a trick to get the cylinders apart. If you need that info or even a picture of the brake down drop me an e-mail
