Ford 9N Tractor Stalls
Michael Freed
07-28-1999 10:19:50
I have a Ford 9N That won't stay running. It starts easily but Won't stay running. You have to play with the choke a lot. Seems to me like it is not getting enough gas. It will stall and it will restart Fairly easy, run for a few seconds and stall again. Even just sitting at an IDle it will just shut down. Any Suggestions?
Steve Bowling
07-05-2006 12:16:15
 Re: Ford 9N Tractor Stalls in reply to Michael Freed, 07-28-1999 10:19:50
Mike,
Did you ever solve your problem with your 9N stalling on you? I"m having the same problem so I was wondering what might have worked for you. I recently installed a tune up kit (spark plugs, points, rotor, condenser, etc.) and it runs smooth with a lot of power, but it still stalls out on me. Any help of what you have learned will be much appreciated.
Steve
Bruce Isaachsen
07-31-1999 14:24:20
Check for a good spark. i had the same problem with my 8N. i replaces points and condenser and am back to work.
Gerald J.
07-28-1999 16:12:09
Check the archives here, and at @ag talk. The subject has been ground to bits every three weeks for the past year. Its probably the screen in the inlet elbow to the carburetor.
Gerald
Sam from Jawja
07-28-1999 17:05:55
 Re: Re: Ford 9N Tractor Stalls in reply to Gerald J., 07-28-1999 16:12:09
Gerald....could you expand on the @ag talk? Where can I find that board. I really learn a lot from this message board and another one would fit my bookmarks just fine!
Thanks....Sam
Gerald J.
07-29-1999 08:28:07
 Re: Re: Re: Ford 9N Tractor Stalls in reply to Sam from Jawja, 07-28-1999 17:05:55
The link I use is:>Link
Probably>Link best to start with:>Link
and>Link use their index of groups.
Another interesting one for JD is:>Link
Gerald>Link J.
