Tractor Talk Discussion Forum
Hercules IXB 3 engine
960
07-16-2006 15:26:25
Does anyone have a source to find parts and or a complete running Hercules IXB 3 four cyl engine?
Duner Wi
07-16-2006 19:26:27
 Re: Hercules IXB 3 engine in reply to 960, 07-16-2006 15:26:25
Sealed Power catalog listed parts for your engine not long ago. Rings ,rod bregs. valve parts and timing gears for clockwise rotation engines.
hectorgemme
07-16-2006 16:41:14
HI I have a complete 1xb3 engine with carburator,magneto and startor.
old
07-16-2006 15:48:51
I have an IXB long block out in my shed. Its not stuck has the water pump head and pan still on it and I also have a few other bits and pieces of the engine. E-mail is open
benny2
07-16-2006 15:36:35
  3???? Re: Hercules IXB 3 engine in reply to 960, 07-16-2006 15:26:25
I think if you read that again it will be 4 instead of 3 as that number indicates the no of cyls in a herc no.
Check out the forklift junk yards they IXB were used in many of them. It also mybe obtained in a diesel version with a D in the model as in IXB 4D
jdemaris
07-17-2006 05:06:17
 Re: 3???? Re: Hercules IXB 3 engine in reply to benny2, 07-16-2006 15:36:35
As other posters already said - the number refers to the timing gears - not amount of cylinders. I just put an IXB5 into a Cletrac OC-3 that originally had an IXB3. They are both four cylinder engines of the same size. The IXB5 is more modern and adaptable to different applications. We bought several complete, brand-new, old-stock IXB5s recently. They come with a bunch of adapters so the exhaust can be mounted in several locations, a distributor igniton or a magneto can be mounted, and there is also an engine-driven hydraulic pump mount if desired.
Gene Davis (Ga.)
07-16-2006 17:54:01
Doesn't the number 3 represent the number of gears in the timing gear cover? My service manual says That.
Glen in TX
07-16-2006 17:23:47
IXB, IXB-3, & IXB-5 were all 4 cylinder. A GO130 Hercules was a 3 cylinder. A JX4-3 is 4 cyld, A QXD-3 & QXD-5 is a 6 cylinder. Anyway new pistons & rings are available from EGGE Obsolete Engine Parts.
champspa
07-16-2006 16:19:09
Zimmerman in Ephrata,Pa.
