Tractor Talk Discussion Forum
ID Plate on Massey Harris Tractor
Ralf from Mich
07-15-2006 12:04:22
I just picked up a MH 30 the castings say it is a 1952, there is no ID plate on it and no indication it was removed or ever had one. All the MHs I have ever seen, and my other MHs have a plate either on the R or L side of the frame has anyone else ever run into this.
Alberta Mike
07-15-2006 20:21:08
 Re: ID Plate on Massey Harris Tractor in reply to Ralf from Mich, 07-15-2006 12:04:22
The serial number is hand stamped into the upper machined surface between the shifting platform (where the gearshift is located) and the steel plate that covers the rear end differential area. It is on the left side in the vicinity of the clutch pedal (when out). It's probably covered with all kinds of paint and crud so start scraping and wire brushing, you'll find it there, the letters and numbers are fairly large but not too deep into the casting.
old
07-15-2006 12:54:59
I have 2 MH 30s and one has the plate and the other one doesn't and also looks like there never was one on it. So yes I've seen them but don't know if its correct or not
