Tractor Talk Discussion Forum
O/T question for some one who knows chev and IH en
old
07-14-2006 17:31:10
Heres the deal I have to fix and or replces the exhaust on my 1980 chev pickup, it has a 350 and I have a set of like new exhause off of an IH 345 engine. Would I be luky enough that the 2 of them would be a exact swap?? I know the trannys will swap so I'm hopeing the exhaust will also what do you guys think/know?
Thanks. Also the exhause for the IH is dual and the chev right now is single and I would really like to go dual on the chev
Don L C
07-15-2006 09:10:06
 Re: O/T question for some one who knows chev and I in reply to old, 07-14-2006 17:31:10
If you have a gas welding outfit and a metal cutting wheel you can make them work.....you may need a few 90 and 45 els. but you can come up with a custom job....I have done it many times in years past..... .
Start at the manifold ...cut and fit each piece, tacking them togeather.....remove the pipe and finish welding it ..Don
The Cisco Kid
07-14-2006 18:20:37
You could have two seemingly identical IH vehicles and unless you had the line setting ticket, you wouldn't be able to interchange anything between the two, each could have completely different engines, transmissions, interiors, exhausts, radiators, radios, rear axles, front axles.
But to answer your question, the mufflers should fit, and you might be able to cram some of the pipes into place, especially if you are good at Southern engineering.
