Tractor Talk Discussion Forum
fuel mileage
99 dodge
07-14-2006 03:37:36
I am looking at a 99 club cab 5.9 auto 4*4. What type of mileage should I expect
Thanks
Chick
07-16-2006 06:38:19
 Re: fuel mileage in reply to 99 dodge, 07-14-2006 03:37:36
HA! We got a 98 extended cab Dodge, with a V-10, and it will run circles around all the diesels pulling, just don't expect any gas milage doing it. About 9.5. Empty, and running 65 mph on the hiway, we get 15.5 - 16 mpg. It has a 3.73 rear end. With 500 ft lbs of torque, and 300 hp, you don't need a 4.10.
Jason - Senoia, GA
07-14-2006 20:05:32
I have a 98 (12 valve) Cummins 4x4 5 spd. I can get 18 - 19 mpg on the highway running fast with A/C on. Run about 16 mpg when towing about 8000 lbs.
JDB
07-14-2006 10:12:46
Have a 94 2wd, not sure what ratio. Lucky to get 15mpg. Nice part is gets about the same pulling a trailer with a 6500 lb tractor on board and the overdrive off.
Luke S
07-14-2006 06:22:58
5.9 diesel or 5.9 gas? Big difference.
Pitalplace
07-14-2006 05:17:17
Depends on what gears. I have the 3.70 (I think) and I get 19 highway. If it has 4.10's stay away, you will have a better tow rig with the taller gears behind this motor.
RobMd
07-14-2006 04:13:01
I have a 2000 with the same and average 12-14mpg. Open highway lucky to get 15mpg. This is unloaded not towing anything.
