Tractor Talk Discussion Forum
cat pony motor
john anderson
07-12-2006 19:09:08
I had just picked up an old sand blaster air compressor.It has a 6 cyl. diesal with pony motor.It has denver name of some sort.It works but it is real old.Should i keep it or scrap it out.The trailer has spoke wheels I think 20 inch.thanks john
jeffcat
07-12-2006 22:28:50
 Re: cat pony motor in reply to john anderson, 07-12-2006 19:09:08
With six pistons going up and down it is 100 or 125 cfm. Most of those units are set up to run two 90lbs hammers. My dads Leroy has a six Continental on it with a 125 rotary screw. It just sits and idles with a 100 lbs sand blaster. If at all possible FIX IT. Jeffcat
john anderson
07-13-2006 12:14:59
 Re: cat pony motor in reply to jeffcat, 07-12-2006 22:28:50
I went and took a closer look today and found out that the compressor has 4 piston on each side and 2 in the middle. 1951 stamped on air tank. It has 500 metal tags on the outside. John
Dale B
07-12-2006 19:45:30
Gardner-Denver is a very good brand and they are still in business. I would fix it up. How many CFM ??
john anderson
07-12-2006 20:21:04
 Re: cat pony motor in reply to Dale B, 07-12-2006 19:45:30
Not sure about the cfm.It has a 6 cylinder pump.It was running a year ago.All the panels for the compressor butterfly hood.Not to mention a wasp nest also.
