Tractor Talk Discussion Forum
O/T '99 Wrangler diagnostic codes
MeAnthony
07-11-2006 16:01:25
My wife has a '99 Wrangler, 6 cyl, 5 speed. Occasionally, some or all of the instruments stop working, and the digital mileage display shows 'no buS' or 'no bu5', not sure because on a digital display 'S' and '5' look alike. The only recall info I can find on this vehicle refers to a loose ground wire under the dash, which I've already checked. Anybody familiar with this code, or have any ideas? I hate to keep spending $40 to have codes read with a scan tool and not have any success locating the actual problem.
Thanks for your time,
Anthony
bradk
07-11-2006 16:34:13
 Re: O/T '99 Wrangler diagnostic codes in reply to MeAnthony, 07-11-2006 16:01:25
MeAnthony,The problem w/your Jeep is at the back of the instrument cluster at the cluster elec.connector.Light corrosion is the cause.
Mopar has a repair harness which needs to be installed using solderless heat-shrink butt connectors.Also you need to clean the male end(cluster end)terminals using a small screwdriver and electric contact cleaner.
Pretty easy fix,so don't let it scare you.
Part #'s at your Chrysler dealer
5016261AA patch harness
4856975 cleaner
