Tractor Talk Discussion Forum
Power Hookup?
Foligno
07-10-2006 06:28:25
Hi All,
I posted this before, but the solutions I got unfortuantely didn't work for me. However, I think I can better describe the situation now.
I "inherited" an old Owatonna swather. I know it was working the year before I got it. It has a make-shift hookup. One cable goes from the battery to what I assume is the solenoid. The other seems grounded ok. There is no key, just a toggle switch. I tried to use a third cable to attach the battery's positive terminal with the toggle connection. I tried both connections of the toggle with no luck (although I must say that this made total sence to me when forum members suggested it). I can't use a screwdriver to start it as the solenoid is surrounded by many moving belts, etc.
Does anyone else have any idea how I can hookup/start this thing??
bradk
07-11-2006 06:34:44
 Re: Power Hookup? in reply to Foligno, 07-10-2006 06:28:25
The three Owatonna swathers we have use a push-button starter switch and a toggle for ignition mounted on control panels on engines.~brad
jones in texas
07-10-2006 12:55:14
Is it a small Ford type solinoid whitch can be mounted almost anywhere.if so it should have apositive battery cable bolted to one side and cable to starter bolted on other side. a small guage wire attached to small conection on sol. then to strter button or spring loaded toggle switch. Does it have a magneto ?
Tramway Guy
07-10-2006 11:19:36
Take another look. Maybe there is no solenoid, it might have a very large pushbutton on the engine or somewhere near it. A lot of the Wisonsin engines were set up this way..the pushbutton takes the place of the solenoid.
You didn't say what the engine was.
john *.?-!.* cub owner
07-10-2006 07:28:34
not familar with Owatona setup, but normal connections for solenoid to start engien would be a hot lead to + side of battery, and a ground to negative side of battery. The switch would either go form + side of battery to a third lead on solenoid, or form ground to third lead of solenoid, dependign on type solenoid. Note, you need 2 switches with this set up. One to operate the starting solenoid, and a seperate one for ignition, unless you have a key swithc that performs both functions. Another possibility is a push to start button mounted on the contorl panel somewhenre.
