Tractor Talk Discussion Forum
White 1270
Fred Mills
07-05-2006 17:48:13
My friend is looking at a 1974 White 1270. It has Fiat 3 cyl diesel engine and 2 stage clutch.There is grinding and resistance when he tries to engage the pto.Price is about $4000. What are good and bad points for this tractor? How severe a problem is the pto grinding? Any special problems associated with the 1270? What is a fair price for a 1270?
Any help greatly appreciated.
JK-NY
07-06-2006 18:14:32
 Re: White 1270 in reply to Fred Mills, 07-05-2006 17:48:13
My neighbors that I worked for as a boy had an Oliover 1465 ,which was a similar Fiat-built tractor. There was a pto clutch lever mounted on the transmission housing on the left if I recall. These tractors pto did not oprate the same as a regular Oliver with live pto where you only used the rear pto clutch.You used the pto clutch and the rear lever was to put the pto in gear. Hope this helps.
Don L C
07-05-2006 19:29:24
Here is a better deal for you---WHITE 4 150....150+ HP $6000...
See it on "PHOTO ADS" #141123
J Schwiebert
07-05-2006 18:56:32
You must be in Canada. There is an adjustment on the clutch. You work at it through the opening on the side. When I worked for the Oliver dealer we sold them as green & white tractors. My neighbor had one and he put thousands of hours on it and it received very little care as it was a grain handling place. One of those deals every body drove it, nobody checked anything on it.You need dimensions for that adjustment let me know. Most customers though they were good on fuel as well. J.
Fred Mills
07-05-2006 19:54:05
 Re: White 1270 in reply to J Schwiebert, 07-05-2006 18:56:32
J. Thank you very much.
I am located in northern lower Michigan.
Fred
