Tractor Talk Discussion Forum
Found a Ford 345C utility... have some ?s
IHC Red
06-23-2006 21:24:17
They're asking $11,900 outright.
~1150 hrs
factory loader
6-way landscape box with ripper teeth.
almost new rear tires
pto
roll-over frame
Over all it's in good condition... no welding or leaks. It spun the tires when going from reverse to forward in 2-Hi at 1200 rpm.
What does this rig weigh ? I can haul about 7000 legally. It's about 30 miles away, but I need to move it about 250 miles to get it to the farm.
Is it about 58 horsepower ? What's the capacity of the loader ?
Thanks in advance.
RodInNS
06-24-2006 09:03:16
 Re: Found a Ford 345C utility... have some ?s in reply to IHC Red, 06-23-2006 21:24:17
I don't know the exact weight, but I would suspect that the tractor and loader would be riding hard on 7000 # plus any ballast. Then add the blade. 58 hp? measured where? The 335 was basically an industrial version of the 3000, which I believe was 38 PTO hp. That would put the GROSS engine around 45-48. That's still a far cry from 58, unless they have dropped a 201 engine in it. Then it could be as high as 55 on the PTO, or as low as 45, again depending on the engine.
I also think at 11900 they're pretty proud of it. 8-9 would be more realistic for the tractor, in my estimation. Add some more for the blade... Mabey a grand for a real good heavy used blade.
1150 hours is nothing either, so ask what it's done to log so few hours, and why it needed new tires with so few hours. That might well be 1150 hours on the second trip, or else it was kept "young" for a long time. HTH.
Rod
