Tractor Talk Discussion Forum
d7 3t inector pump problem
joey d
06-21-2006 11:43:30
i was hopeing someone could help me in adjusting the govenor or setting the rack "pressure" on my 3t.i have cleaned the air filter ,changed the fuel filters. made sure the line are open coming from the tank but still havent helped the problem.it seems to be runnning at about half throttle not really enough to work with. the fuel pressure gauge is broke does anyone know how much pressure it should have , any help or ideas would be greatly appreciated. thanks
hectorgemme
06-21-2006 14:32:44
 Re: d7 3t inector pump problem in reply to joey d, 06-21-2006 11:43:30
HI You should instaled a new fuel gage after if you have a good pression you have to check your injector you should have one no good.
joey d
06-21-2006 18:40:04
 Re: d7 3t inector pump problem in reply to hectorgemme, 06-21-2006 14:32:44
thanks for the input hector,do you know how much pressure it should have if i hook a gauge up?do you know how to turn the pressure up?
hectorgemme
06-22-2006 10:59:56
 Re: d7 3t inector pump problem in reply to joey d, 06-21-2006 18:40:04
HI I am sorry am not a expert send your question on ANTIQUE CATERPILLAR MACHINERIE and you should have the god answer. HECTOR
joey d
06-22-2006 16:22:18
 Re: d7 3t inector pump problem in reply to hectorgemme, 06-22-2006 10:59:56
thanks for your time and info hector
jerry watkins
06-21-2006 14:19:28
WOULD BE GLAD TO DISCUSS THE PROBLEM WITH YOU QUITE A BIT MORE THAN I CAN WRITE HERE E MAIL ME AND I WILL TRY AND GET ON THE PHONE WITH YOU SEVERAL ADJUSTMENTS BUT MOST ARE SIMPLE AND THE GOOD THING IS THAT PUMP IS PROBABLY NOT BAD
joey d
06-21-2006 18:44:55
 Re: d7 3t inector pump problem in reply to jerry watkins, 06-21-2006 14:19:28
thanks for your input jerry did you get my e-mail?
