Tractor Talk Discussion Forum
Pulley Troubles - - Help
TomTX
06-20-2006 16:32:26
The water pump pulley, which has 2 belt grooves for water pump and fan, and a third single belt groove for the AC compressor belt on my MF690 has eaten out some metal along the woodruff key slot. The water pump shaft has the dish shaped side of the woodruff key, and the pulley has the straight cut key way. Dealer said new pulley is $505, which sent me into shock. Pulley MF part number is 745609M1, Perkins part number is 31154281. Question 1. Has anyone ever had a machine cut a new keyway in the pulley, straight 5/32", on the opposite side, away ffrom the wallowed out keyway? The water pump shaft is not an issue as I am replacing the pump.
Question 2. Know where to get a used or cheaper pulley?
Many thanks for help.
Tom
Don-Wi
06-21-2006 00:22:48
 Re: Pulley Troubles - - Help in reply to TomTX, 06-20-2006 16:32:26
I'd have the machine shop measure it first, it should be just a standard size and not metric, so I'm guessing either 5/8" or 3/4". If it measures more than .003 over, I'd either pein the inside with a center punch if it's not too big, or bore it out and sleeve it. I've done both at my last job, now I work at another shop that doesn't do any repair work for farmers.
As for the key, put it at 180 from the original and it'll be fine. I've even seen JB weld used in severe conditions and was holding up last I saw.
Donovan from Wisconsin
Russ from MN
06-20-2006 19:10:55
If there is enough material in the hub it could be bored out, and a sleeve shrunk in. then bore and key it, any good machine shop should be able to do it.
KENT
06-20-2006 17:25:31
OOPS---IT SHOULD BE PITTSBURG WITH 2 T'S
KENT
06-20-2006 17:19:50
TRY PITSBURG TRACTOR ON PITSBURG, TX---THEY ARE MASSEY DEALERS AND HAVE A MASSEY SALVAGE YARD---DO A GOOGLE SEARCH FOR THEIR WEBSITE---HTH
KENT
TomTX
06-20-2006 17:46:48
 Re: Pulley Troubles - - Help in reply to KENT, 06-20-2006 17:19:50
Kent, thanks, I got their mnumber off the net and will call them tomorrow. Tom
jones in texas
06-20-2006 17:17:06
An industrial machine shop should be able to cut the keyway you need. I had a similiar problem with an car crankshaft and pulley.The machine shop solved my problem.
TomTX
06-20-2006 17:48:24
 Re: Pulley Troubles - - Help in reply to jones in texas, 06-20-2006 17:17:06
Jones, thanks. I will try calling on machine shops tomorrow. Tom
UncleTom
06-20-2006 17:22:23
I know it can be done, I use to cut keyways in sprockets 30 years ago at my old job. The question is how much oversize is the hole worn?
TomTX
06-20-2006 17:52:34
 Re: Pulley Troubles - - Help in reply to UncleTom , 06-20-2006 17:22:23
Uncle Tom, I am worried about the hole. It still fits the shaft (without woodruff key in place) but has a tiny bit of wobble, just enough to feel. I was hoping that with a new keyway cut on the opposite side, and a new flat washer, lock washer, and lock nut, that it will tighten up enough to hold. Is there any other way I can tighten it up a bit? Thanks for your help. Tom
Bill WI
06-20-2006 18:17:32
 Re: Pulley Troubles - - Help in reply to TomTX, 06-20-2006 17:52:34
A different pulley would probably be better. Always cut the new keyway 90 degrees around just so you don't compound the wobble. Sounds like your best bet in salvaging the pulley would be to bore the old one and make a bushing with a keyway and press it in with press fit. Will cost though.
