Tractor Talk Discussion Forum
should I do it?
Tim Shultz
06-19-2006 08:27:42
on my 73' ford, I cleaned out the PCV valve and oil filler valve.. I think that was why I had oil in the air filter.. but now should I clean out the valve covers? if I did take them off, could I seal them up with RTV sealer? or would I need to go to napa and spend $50 on new gaskets? :(
I am just afraid that all the junk in the valve covers will plug up the PCV again.. help me out please! THANKS! Tim Shultz
Leland
06-19-2006 19:13:06
 Re: should I do it? in reply to Tim Shultz, 06-19-2006 08:27:42
Just use the goop my truck engine has only 2 gaskets the head one the rest of the motor is sealed with RTV of some sorts .
the tractor vet
06-19-2006 09:04:42
Well it was not uncommon for the old FE 's to get the oil return hole blocked and FIFTY BUCKS FOR VALVE COVER GSKTS????? i think that is a bit high . As far as the GUPPUY GOOO myself i do not use it but in the coners of the intake and then vary sparingly .be able to get them valve cover Gskt.from ford and i don't think that they would cost that.
