Tractor Talk Discussion Forum
Help!!!!! Ford Tire Exchange in a hurry!!!!!
Casey in Ky
06-06-2006 19:07:08
Does anybody know if I could unbolt rims and all off of a '65 Ford 3000 and mount them on a '92 model Ford 4830?? The steering box went out on the 3000 back a couple of months ago and I'd hadn't got a chance to fix it. Tonight I was raking and busted a rear tire on the 4830. In a real pickle here, nobody does emergency tire calls around here. The 3000 has new rear tires, but they are a lot smaller, 16.9x30's on the 4830, not for sure on the 3000, but I know they are a lot smaller. Will the rims match up?? Any suggestions??? Thanks,
Casey
TomTX
06-07-2006 05:53:23
 Re: Help!!!!! Ford Tire Exchange in a hurry!!!!! in reply to Casey in Ky, 06-06-2006 19:07:08
Sounds like your fighting windmills here. A simple removal of one tire and replace with a new one is much quicker and much less labor than a bunch of ill-fitting switching, and then having to re-switch. AND in the end you still need a new tire. Simple solutions are sometimes the best. Tom
RickB
06-07-2006 03:30:38
Not gonna fit.
aFORDable
06-06-2006 19:25:04
Don't know about the exchange but measure the lugs on both rims (distance across at 2-3 places) and that should tell you if the rims are interchangeable.
