Tractor Talk Discussion Forum
oil loss
37 chief
06-04-2006 23:32:46
I need to add a quart of oil each day I use my AC model M. I pull a 8 ft. disc, and it gets a good workout. I see a puff smoke now and then,when going down a steep bank, but not a lot. It still has a lot of power. It doesn't seam to leak. I don't plan to do anything now, but it seams a little excessive. Stan in calif.
Jerry/MT
06-05-2006 14:15:02
 Re: oil loss in reply to 37 chief, 06-04-2006 23:32:46
If you're using the correct oil, the plugs stay clean and you don't see any leakage I'd say that was probably normal for your machine. You say you see a puff of smoke when going down hill and that maybe indicative of worn intake valve seals and/or guides.
RustyFarmall
06-05-2006 07:29:42
I'm with Allan on this one, one quart of oil per day is more or less normal. I do not consider it to be excessive at all.
Allan In NE
06-05-2006 06:05:04
Hey Stan,
Back when I was farming heavy, I can remember sometimes using a couple of quarts of oil a day in those diesels. These were new tractors at the time too; just part of the game.
Keep on a tuggin' and just remember to check the levels every morning. Think of all the work that the old monsters do. :>)
Allan
TomTX
06-05-2006 03:29:54
What kind of oil are you using? Tom
37 chief
06-05-2006 08:00:45
 Re: oil loss in reply to TomTX, 06-05-2006 03:29:54
I am using straight 40 wt. It is Pep Boy's brand made by Valvoline. Stan
TomTX
06-05-2006 14:08:39
 Re: oil loss in reply to 37 chief, 06-05-2006 08:00:45
Won't cost you much so try changing oil and filter. Use quality filter and your choice of Mobil Delvac 1300 15W40, Shell Rotella T 15W40, or Chevron Delo 15W40. Run a while and change again. Your troubles might be behind you. Good luck. Tom
37 chief
06-06-2006 00:46:41
 Re: oil loss in reply to TomTX, 06-05-2006 14:08:39
I did use the Chevron Dello 15-40, and I had a piston sieze twice. I tore it down,and replaced the rings after a hone job. I could never find the problem. I went back to straight oil and have never had the problem again. Stan
