Tractor Talk Discussion Forum
farmall 806 1-4 lever not shifting
timjsch
05-29-2006 08:06:45
My 806 is in first gear and the roll pin came out on the bottom rod where the shaft goes into the leakage. Does anyone know if there is a certain plate I can take off to push this rod back up to reconnect?
bshannon
05-29-2006 09:31:02
 Re: farmall 806 1-4 lever not shifting in reply to timjsch, 05-29-2006 08:06:45
This has happened to us a couple times, as I recall you have to reach up underneath, it helps to take the sheet metal off around the dash area and also to have a couple extra hands.
bshannon
05-31-2006 14:56:48
 Re: farmall 806 1-4 lever not shifting in reply to bshannon, 05-29-2006 09:31:02
Thanks, I have gotten in to the tractor by taking the tin off to see what was causing the problem. I need to know if a plate comes off the tractor somewhere to push the rod up into the linkage to put the roll pin back in.
