Tractor Talk Discussion Forum
ford 9n hard start when hot
evadamsteiz
05-29-2006 07:24:58
my 9n runs great and starts fine when cold, but when you shut it down hot and try to restart, it may or may not fire up. the longer it cools down, the more likely it will start. any ideas?
davpal
05-29-2006 22:54:41
 Re: ford 9n hard start when hot in reply to evadamsteiz, 05-29-2006 07:24:58
My 9n started doing it last year. It was the coil. It had an original ford coil still on it. It starts much better now when it is hot with the new coil. About $35 bucks at tsc.
old
05-29-2006 07:50:04
Your coil might be getting weak. The next time you have problem starting it hot check to see if you have a nice brite blue spark. If you don't then the coil is probably your problem
