Tractor Talk Discussion Forum
Massey Harris 44 surging
JRBSR
05-24-2006 12:36:26
My Massey Harris 44 1948 surges uncontrollably when put under a load. Any ideas on my problem ??
I replaced the governor. Maybe its not set correctly. Any hints on setting it.
Thanks
oliver fan
05-24-2006 19:35:35
 Re: Massey Harris 44 surging in reply to JRBSR, 05-24-2006 12:36:26
You have a small screw on the front of the govenor housing. On the inside of the housing is a small spring that is hooked to that screw. All you do is turn that screw in a little at a time until you get the lope out of the engine. YOU HAVE TO SHUT THE ENGINE OFF TO ADJUST THAT SCREW. an remember a little goes a long way, so don't turn it in very much each time.
old
05-24-2006 12:57:00
Carb problems will cause it to do that. What is happening is that the carb is set to lean or the main jet area is clogged with junk.
